caznandy
Sep 15, 2018Tutor
NETGEAR PLP1000-100UKS 1 Port,1000 Mbps, 1 Gigabit Port Powerline Adapter
Please can anyone tell me if I can add a Wi-fi extender to my exiting
netgear plp1000 powerline adapter
Sep 15, 2018Guru - Experienced User
You can use a wifi extender the powerline's wifi network.
Or you could add a second powerline AP - that is a second PLW1000v2 (though unfortunately they are often paired with a wired powerline adapter that you don't need).
caznandy
Sep 15, 2018Tutor
Hi stephenB thanks for the reply
if I get a second ap like the PLW 1000 will this connect to my existing plp1000 by the push and Secure button
- StephenBSep 17, 2018Guru - Experienced User
caznandy wrote:if I get a second ap like the PLW 1000 will this connect to my existing plp1000 by the push and Secure button
Yes, you can set it up to use the same PLP1000. It's been a while since I used powerline, so I'm not sure if there's a trick needed on push-and-secure or not. I have connected multiple adapters to the same powerline network though.
- caznandySep 22, 2018Tutor
Ok thanks I will give it a go
