THRB
Sep 16, 2018Initiate
Netgear Powerline 1000 PL1000 - wifi access failing
Hi - My Netgear Powerline 1000 booster has worked fined for well over a year. However, we now cannot get any devices logged onto the signal despite that all the LED indicators are showing green/blue...
- Sep 20, 2018
Many thanks for the reply. Yes eventually we reset using an ethernet connection and it is now back up and running. Appreciate the time you took to reply. Regards
michaelkenward
Sep 19, 2018Guru - Experienced User
Checked for any local wifi interference? Have the neighbours added something on the same channels?
