THRB
Sep 16, 2018Initiate
Netgear Powerline 1000 PL1000 - wifi access failing
Hi - My Netgear Powerline 1000 booster has worked fined for well over a year. However, we now cannot get any devices logged onto the signal despite that all the LED indicators are showing green/blue...
- Sep 20, 2018
Many thanks for the reply. Yes eventually we reset using an ethernet connection and it is now back up and running. Appreciate the time you took to reply. Regards
Sep 17, 2018Guru - Experienced User
I've moved this into the powerline subforum.
We need some more information - particularly it would be useful to figure out if the problem is with the powerline connection or the WifI.
Have you tried connecting through the ethernet port on side of the WifI module? If so, what was the result?
THRB
Sep 20, 2018Initiate
