Johnny_Normal's avatar
Aug 11, 2020
Netgear powerline plp1000 ethernet light not turning on
Hi, I have my netgear powerline wifi 1000mbs for the best part of a year and they worked great until today. I am not sure why.
The ethernet light won't turn on on the adapter near my pc, but the other two light are fine (the power light and the connection to the other plug). The one next to the router has 3 greens.
I have tried a factory reset of both devices and reconnecting them, I've tried a power cycle of the router, I've used 3 different ethernet cables, I've tried swapping the adapters around, I've tried different wall sockets. Nothing seems to work for me.
Is there anything I can do or has it broke?
  • michaelkenward's avatar
    michaelkenward
    And this is with something plugged into the LAN port? They don't come on when empty.
    • Johnny_Normal's avatar
      Johnny_Normal
      Initiate
      Yep, my pc was on the entire time (only reason I saw it was broken was because I had no Internet access on it). I bought a new set of the same ones and realised that it was the ethernet port on the pc. Same thing happened with a brand new pair. But for some reason it is working again with the original set. I have no idea why to be honest. But its working again so that's the main thing!
