LFloresTX
Dec 17, 2016Aspirant
NETGEAR ProSAFE GS116NA
I purchased NETGEAR ProSAFE GS116NA from Amazon.. The Cable company installed an ARRIS DG2470 Touchstone Gateway with 4 ports. When I connect my unmanaged switch to the Gateway from the Cable company I lose all internet connectiviy from the Wireless and Ethernet. is there a specfic port that I need to connect to on the ARRIS or my Netgear switch? I'm stummped.. is the switch compatible to the gateway?
- clithesProdigy
Are you using the correct cable?
The user guide states you need a cross-over cable when connecting to a hub (page 33):
Hope this helps
- LFloresTXAspirant
For a managed switch I would agree that you need a crossover. But this one is unmanaged so my thought was it would act as a pass through.
I'll try it and see what happens
- clithesProdigyYeah I have no knowledge of the Arris gateway but thought it might be worth a try
