erwinodendaal
Jan 07, 2016Tutor
"No device in network"
Hi, I want to connect to my powerline 500AV adapters by using the NETGEAR Powerline Utility D 3.1.0.3 on my Mac. But I keep getting the message "No device in network" although both adapters do wo...
- Jan 12, 2016OK should work with the latest version of the utility (which you have)
Does it not even recognise the one you have plugged into your Mac ?
clithes
Jan 09, 2016Prodigy
Hi,
some adapters are unfortunately not compatible with Mac versions of Netgear Genie or the Powerline Utility, as in this example:
http://kb.netgear.com/app/answers/detail/a_id/24523
What model adapters do you have?
- erwinodendaalJan 12, 2016Tutor
