erwinodendaal
Jan 07, 2016Tutor
"No device in network"
Hi, I want to connect to my powerline 500AV adapters by using the NETGEAR Powerline Utility D 3.1.0.3 on my Mac. But I keep getting the message "No device in network" although both adapters do wo...
- Jan 12, 2016OK should work with the latest version of the utility (which you have)
Does it not even recognise the one you have plugged into your Mac ?
clithes
Jan 12, 2016Prodigy
erwinodendaal
Jan 18, 2016Tutor
I will try to connect the device when I have time.
Thanx for the help
