Hunterc921
Jul 04, 2017Follower
No WPS button on Google router
How do you connect powerline PL1200 to Google Wifi Router that doesn't have WPS button?
1 Reply
- clithesProdigy
The PL1200 doesn't need to know anything about your router, it simply extends a LAN connection as if it was a physical cable. The device at the other end will not need to know either, as you are connecting by cable. a WPS button is only to simplify WiFi connections, which you aren't doing in this case.
Hope this helps.
