rags1's avatar
rags1
Pick a Plug LED losing connection
Just purchased a set of the powerline 2000 to improve 2nd floor internet. Followed directions for installation. The Power and Powerline LED come on solid green initially when plugging in. After 2-3 minutes the Powerling LED goes off and does not come back on. It does does turn red or amber, just goes from solid green to off. Verified that both electrical outlets are on the same leg. Also tried in different plugs in the house even in the same room. Always the same thing, Powerline LED comes on and stays on for 2-3 minutes then goes off. Tried doing the security reset as well but no result. Powerline LED stays off.
  • I just purchased a retail boxed pair of PLP2000 powerline units.
    I tried every power outlet in my home and they never indicate finding each other.
    'Pick a Plug' comes on briefly on powering up then goes off.
    • michaelkenward's avatar
      michaelkenward
      See above. Same questions get the same answer.
      Or explain what you have done.
      • TooFar's avatar
        TooFar
        Tutor
        Self explanatory.
        Followed instructions, including reset and resync of keys Tried on every single outlet always same result. Units 'pick a plug' led always comes on briefly then goes off and stays off. This seems to indicate the units cannot detect each other on any outlet of my premises *for whatever reason*.
        Went through this with Netgear support - their response - return the units for refund.
        I just thought I would ask here if anyone knew of a way to get them going.
        Thank you for the non answer forcing me to repeat myself. The units are being returned today.
    michaelkenward
    Does the Powerline network work as expected?
    It may be a case of the thing going into hibernation when nothing is happening.
    Sadly, Netgear stopped providing software to manage its powerline stuff some time ago. People have used ZyXel's Powerline utility to manage Netgear plugs.
    The desktop genie for Windows can also show what is going on in your Powerline network.
    genie Landing Page | Apps | Discover | Home | NETGEAR
    You may have to dismiss an annoying pop-up that tries to push a mobile app down your throat.
    Look for the Powerline icon on the Network Map.
