Dean_T's avatar
Dean_T
Pick A Plug on Powerline 1200 is green, then red when connected
When I connect my Powerline Adapter 1200 to the router and wall and whatnot, the "Pick A Plug" feature turns a steady green. However, when I connect my PC (Windows 10), it turns to red. I have used this product before without flaw while living in an apartment, but I just moved to a house. I usually use it through an outlet extender (has three outlets), and I know you are not supposed to do this, so I tested again just plugging straight into the wall. The results were the same; "Pick A Plug" was green, until I plugged the ethernet cable into my PC, and it turned red. Now the distance I am from my router has increased, but I do not think this is the problem, as the "Pick A Plug" shows green before plugging in my PC. While connected to the network through the powerline adapter, I ran the Windows "Network Troubleshooter," but it didn't return anything wrong. Any help is appreciated.
  • Problem with powerline devices is that they're sensitive to interference. Things like cell phone chargers, surge protectors, arc fault circuits, gfci outlets, high draw appliances, old/bad wiring,  or even just electronics that are going bad can all create interference.
    Have you tried the powerline devices both in the same room on the same circuit? If they connect that router, then its probably something within the home that's injecting interference in the power system.
    Like I said, random things can do this and if you've recently moved, it could be something within the wiring causing the issue.
  • plemans's avatar
    • michaelkenward's avatar
      michaelkenward
      That's the first move.
      But the symptoms you describe are odd.
      I can't tell from your message if the network is actually working. Are there problems? Or are you just puzzled by the red light?
      • Dean_T's avatar
        Dean_T
        michaelkenward I thought they were odd too, especially after searching online for anyone else with the same problem. When I was experiencing problems the night before, I didn't check the network, so that may have been the problem. However, when I woke up this morning, the network was working fine for my family (although they are connected over Wi-Fi and ethernet), and after a bit more unplugging and plugging it just started working. So I hope it stays this way, and for now I will leave it as it is.
    • Dean_T's avatar
      Dean_T
      Thank you for the advice plemans, but when I woke up this morning, it began working for some reason. In case this is just luck and it goes down again, I will be sure to do as you said, and test them on the same circuit. Until then, here's hoping it stays working.
