DOC007's avatar
DOC007
PL 1000 connectivity issues
I just purchased the PL 1000 as an ugrade so that I can utilize the wireless capabilities and not just plug-in. So I was able to get it working plugged in as well as WPS on my cell phone. However, wh...
  • michaelkenward's avatar
    michaelkenward
    Jul 13, 2017
    There are two different things going on there.
    The way to get into http://www.mywifiext.net/ is not the same as the way into the wifi.
    As the bit you quote says First you need to be connected to the wifi.
    DOC007 wrote:
    There is a wifi key on one of the plugs, but what would be the user name if used.
    The wifi device you are trying to connect to should show and SSID for your network.
    The manual says:
    The network name is printed on the product label and is similar to Netgear##_EXT or Netgear##-5G_EXT.
    DOC007 wrote:
    Not very user friendly when instructions tell you to use admin/password initially.
    Indeed. Can't argue with that. Not at all user friendly.
