ayozdob
Aug 02, 2021Aspirant
PL1000 Pick-A-Plug LED off throughout the house
Title. My PC and router are connected to ethernet cables connected to the PL1000. Last night, suddenly, both stopped functioning and the Pick-A-Plug light has gone off on both. What can I do to fix th...
ayozdob
No, however they also dont work individually. Because of the setup of the house, they cant be in the same room. They also don't work when one is disconnected.
Aug 02, 2021Guru - Experienced User
ayozdob wrote:
No, however they also dont work individually. Because of the setup of the house, they cant be in the same room.---its for testing to see if they work. having them on the same circuit is an attempt to remove as much interference as possilble. They also don't work when one is disconnected.
