patste_nl's avatar
patste_nl
PL1000 won't establish network connection
Hi, I do have a home network with a different IP range as the default home range 192.168.1.0/24. When I plug in one of the two adaptor in an outlet and connect it to my switch, I see it appear in m...
  • patste_nl's avatar
    Nov 05, 2017
    Problem solved. I forgot to push the security button after putting the adapters on the outlets.
