QuinnC
May 18, 2021Follower
Pl1000v2 keeps shutting off my wifi
Hello! So I just got the pl1000v2 and everytime I set it up, it ends up turning off the wifi in my house. I'll get the wifi but it will say no connection, for every device in the house. When I unplug ...
michaelkenward
May 19, 2021Guru - Experienced User
QuinnC wrote:
avail.
One thing I should mention is that my room mate upstairs uses this and he's had no problems. Could that be effecting mine? We both use the same router. Any help would be greatly appreciated.
That bit is puzzling.
Are you saying that there are two independent Powerline networks? Two plugs connected to the router and two remote plugs?
Powerline plugs are effectively just bits of wire. There isn't much that they can do to affect your wifi. But it sounds like you may have a complicated local network.
