TravisHamon
May 03, 2018Follower
PL1000v2 suddenly stopped working
My PowerLINE 1000 stopped working for my laptop the other day. The adapters are each plugged straight into the wall in the same room. Both the Power LED and the Ethernet LED are green lit but the Pic...
michaelkenward
May 04, 2018Guru - Experienced User
Is that a wired connection?
TravisHamon wrote:
I tried plugging in another computer and the new device connected straight to the internet.
If that means that you swapped out the offending laptop and connected a different PC, then that suggests that it is the laptop that is where the problem lies. Have you tried connecting it to something else?
