spartus434
Jun 27, 2017Aspirant
PL1200 Is a piece of junk!!!!!!!!
Don't buy!!!!!!! It loses connection all the time. Get a ZyXEL PLA5202 You will be happy you did, because the Netgear PL1200 wil give you nothing but headachces. The ZyXEL lets you turn off power...
- Jul 04, 2017
I find power saving mode/standby mode causes no end of problems with Netgear powerline adapters. Netgear will tell you that the PL1200's don't have standby mode, or that it cannot be switched on or off, however Zyxel's powerline software finds the setting and changes it.
Check out my earlier post here:
https://community.netgear.com/t5/Powerline-Networking/Netgear-Powerline-1000/m-p/1129924#M3771
This explains the software version you can use to turn off standby mode on the Netgear units
I have done this on all my newer Netgear adapters (PL1200 and PLP1200) and they work perfectly well now.
The link to the Zyxel software is here:
ftp://ftp.zyxel.com/PLA4201_v2/software/PLA4201%20v2_V7.0.2.14.0611.zip
Hope this helps
clithes
Jun 30, 2017Prodigy
Most likely your house wiring or noise than the unit itself, unless you were just unlucky and had a faulty unit. I have plenty running in my home (and the home before it) perfectly well.
spartus434
Jul 03, 2017Aspirant
Over and over again people want to blame the wiring in the house. That is horse do do. I live in a newer small apartment. The ZyXel units connect right up and remain connected. I can watch TV through the night, fall asleep and wake in the morning and the ZyXel unit are still going strong. The Netgear units drop out after about 20 minutes. I replaced the Netgear units three times and the results were the same everytime.
