Gunfiend's avatar
Gunfiend
PL1200 won't show up on my adapter list
I just recently had to reinstall windows because it was damaged by force restarting my computer and that caused all my settings to be erased. I had been happily connected to the Powerline before, but now I am stuck being connected using my wireless adapter. I don't know what I did last time to get my computer to connect using the Powerline, but I am unable to get it to work again now.
  • Network adapter card / driver not installed correctly after Windows rebuild ?
    • Gunfiend's avatar
      Gunfiend
      Ok, so that helped me a ton. I looked online and apparently under Device Manager, my ethernet cable should not be labeled as Ethernet Controller, but it is. It says it needs an update, but I am not sure how I might go about getting that update when I tried to scan the internet for it, but it didn't work.
      • clithes's avatar
        clithes
        Prodigy
        If you don't know the make and model of your motherboard run the Belarc adviser free software:
        http://www.belarc.com/free_download.html
        From that you can identify your motherboard details.  Once you have these go to the manufacturer's website and download network adapter drivers and install.
        Hope this helps
    • Gunfiend's avatar
      Gunfiend
      Exactly as you said, I just had to go download a couple drivers, and boom, connected. Thanks a lot!
