gerardm27
Aug 27, 2017Aspirant
PLP 1200 not working on PC
I have just had this issue with my new PLP1200 I bought a month ago. The lower led (Pick A Plug LED) varies from On to Green but doesn't let my PC connect via ethernet. I have the other Adapter set at...
michaelkenward
Aug 28, 2017Guru - Experienced User
Do you know that the PC's LAN socket is working and properly configured?
Do you have the right drivers for your PC's LAN?
If you can plug the PC directly into the router and its works you should be OK.
If this is a Windows PC, have you run the troubleshooting wizard for the network?
The problem solver does nothing (as always) and it still says Unidentified Network - No Internet Access
What's that?
gerardm27
Aug 28, 2017Aspirant
It solved just by having it unpluged the whole night, idk what happened :/
