loveall27
Jan 07, 2019Aspirant
PLP 2000 and adding additional PLP1200
I have two PLP2000 and both are working fine. Pick a plug LEd light is solid green (Means throughput is more than 80 mbps). Now I bought additional two PLP1200 and when I added this PLP1200 then pic...
michaelkenward
Jan 08, 2019Guru - Experienced User
Did you add the new plugs to the existing powerline network? Or did you set up a separate network with the PLP1200s, with one connected to the router?
Remember, when adding new plugs to an existing network, you need to follow this advice:
>>> Adding a powerline adapter to an existing powerline network <<<
loveall27
Jan 08, 2019Aspirant
I am adding PLP1200 as additional plug in the existing PLP2000 network. I have followed instructions as per this link too
https://kb.netgear.com/22165/Adding-a-powerline-adapter-to-an-existing-powerline-network
