Markbebe
Jul 17, 2019Follower
PLP1200 Loses connection after 5 ish minutes
Hi So I have two PLP1200 adapters connected with a wireless router on both ends. I've had this setup since 2016 with this problem only occuring once last year, where it fixed itself somehow. So the ...
michaelkenward
Jul 18, 2019Guru - Experienced User
Markbebe wrote:
Hi
How does that work? Two routers on one network?
Markbebe wrote:
So the problem is that the adapters suddenly stops transmitting internet..
What symptoms do you see?
What does "stops transmitting internet" mean?
The Ethernet goes down on some device or other?
