Stormfl1
Nov 18, 2018Aspirant
PLP2000 Problems
Hello. I have a Powerline 2000 with the extra outlet and I have been running into problems with it. I originally got it working and it was pretty smooth the first week I got it, but then things went ...
michaelkenward
Nov 19, 2018Guru - Experienced User
Stormfl1 wrote:
I can't connect to the "Unientified network" and it seems to have no Internet. I troubleshooted the network to see what was going on and it says "Ethernet" doesn't have a valid IP configuration.
That sounds like a Windows issue rather than anything to do with the Powerline plug.
Plugs do not have an IP address, only the things that you connevct to them.
Stormfl1
Nov 19, 2018Aspirant
Hello. I just tried plugging in the Ethernet cable that I had plugged into my desktop, into my laptop and I ran into the same issue. I also swapped the ports on the modem to make sure it wasn't a broken port, and everything is fine. The issue doesn't seem to be windows, it seems to be the Netgear Powerline.
- michaelkenwardNov 20, 2018Guru - Experienced User
I don't see how you can reach that conclusion.
You disconnect one Windows PC from the network and replace it with another one and you see the same message.
It might help if you said what else is on the network, the modem for example.
