RandomDave's avatar
RandomDave
PLP2000 upload speed is slow.
Hello Netgear community!
I've recently installed a PLP2000 kit. The download speed is fine (120Mbps) but the upload. Not so much. .4-2Mbps.
Wired to the router I'm getting 1-1.2Gbps down and 40-50Mbps up.
Suggestions?
  • Thanks for the suggestions all. Turns out to be something bizarre with the Windows install I hadn't run into before. Still troubleshooting it.
  • Hey! Try these quick fixes:
    1. Plug both units directly into wall outlets—no power strips.
    2. Avoid outlets near noisy appliances (fridge, microwave, etc.).
    3. Reset both adapters: Unplug, wait 30s, plug back in, then press reset button 2-3s.
    4. Test with units closer together or on the same circuit.
    5. Use Cat5e/Cat6 cables and check LEDs (green = good).
    Upload should hit 20-30Mbps if the line’s clean. Let us know!
  • plemans's avatar
    have you tried thees powerline devices on the same circuit? It wouldn't be the first time that interference or circuit separation (running through an ARC fault circuit) reduced speeds
  • CrimpOn's avatar
    CrimpOn
    It would help to know how this Powerline adapter is being used.
    • To connect an individual device to the router?
    • To connect the router to a modem or fiber ONT?
    • To connect a satellite to a router?
    The more detail the better. Thanks.
