JessQ
Aug 24, 2018Aspirant
PLW 1000 - Connecting other networks to mine - MASSIVE SECURITY RISK
I live in a condo/appartment block. I bought the powerline adapter and connected it to my network. When checking the ISP Modem, I can see other ISP Modems on my network, through the port where the Po...
michaelkenward
Aug 25, 2018Guru - Experienced User
JessQ wrote:
To change my encryption key to make sure it wasn't the lack of encryption. I have also turned of the Wireless component as I do not need this. I am still pulling other peoples networks!
What do you mean "pulling other peoples networks"? You can see their wifi? You can see them on the wired LAN network?
I don't know about anyone else, but this looks more like the rest of the people on the network should worry, not you.
You may be able to see them, but can they see you?
What else is on your network? Router? Modem?
- JessQAug 27, 2018Aspirant
By 'Pulling other people's networks' I mean, I can see their router's/modems on my network. When I ipconfig /release | ipconfig /renew I am able to connect to their network, but still using the name of my wifi. I can also see their devices on my network when running a scan using Advanced IP Scanner.
If I can see them, connect to their modem's and get to their modem's gateway address', I'm pretty sure they can see me.
On my network, I have my ISP's modem/router which connects to the Netgear device, and then the other netgear device on the other side of my apartment. There are no other devices.
- michaelkenwardAug 27, 2018Guru - Experienced User
I see no answer to these questions:
You can see their wifi? You can see them on the wired LAN network?Any evidence that they can see you? "Pretty sure" won't stand up in court.
What happens if you remove the Powerline plug from the network?
JessQ wrote:
On my network, I have my ISP's modem/router ....
Yes, but what is it?
My apologies.
I can see their wifi SSID in the list of possible connections in the Windows Network Connections. When I change the IPConfig with the release and renew command it does not switch me over to their SSID. It stays on my SSID, but the IP address and Gateway address changes. I can then access their Modems and see their WIFI SSID is completely different to the one I am connected to.
I can see the other modems on the wired LAN network, the modem can see them as if they were wired in from port 2 (port 2 on my ISP's Modem/Router is where the Netgear Device is plugged in).
Evidence that they see me?
I do not know if this is evidence, but there is a device, which is NOT mine, which is connects to my network only when the Netgear device is plugged in. When the Netgear device is removed, the other connecting device dissapears.
When the netgear device is removed from the network:
I can no longer see any of the other networks on my LAN.
What is it?
It is a Ubee Avanced Wireless Voice Gateway -Model DVW32CB
