dbosley's avatar
dbosley
Follower
Jul 14, 2016
PLW 1000 the computer is asking for a password and I have noi idea on box where that is. Any help?
I just bought a powerline PLW 1000 wifi plug in. I plugged in the unit, attached it to the router and it lit up . My kindle finds it and indicates the signal is excellent. It asks for a password. The quick install directions state this is on the box, but I can't find it. Any suggestions?
  • michaelkenward's avatar
    michaelkenward
    I assume that it is the wifi password you want to know.
    Try the manual, page 11.
    Customize Your Network Settings
    When prompted to log in, enter the user name admin and the
    password password.
    I assume that you have already got your powerline adapters talking to each other. (See page 7.)
    • clithes's avatar
      clithes
      Prodigy
      Its on the label on the back of the unit, here's mine (yours will be a different password):
      Hope this helps
      • PBeditor's avatar
        PBeditor
        Thanks for this. It was helpful. I just wish I had found it two hours earlier. Has anyone mentioned to Netgear technical writers that this is exactly the type of image needed in the manual for this device? Nowhere in the manual does it say that the password is labeled as the "key" on the product label on the device.
