ErikRoss
Jun 06, 2016Aspirant
PLW1000-100PES wireless reversed mounting
I have read information on product, and I want buy this: Netgear PLW1000-100PES AC650 WiFi . But before you buy it, I would have a question to ask I want know, if it's possible connect th...
- Jul 12, 2016
Hi ErikRoss,
The setup that you have presented should work.
ErikRoss
Jun 25, 2016Aspirant
my Ethernet line ends where there is WiFi coverage, in this way can extend the it.
JamesGL
Jun 30, 2016NETGEAR Employee Retired
Hi ErikRoss,
Which connection do you want to extend? Is it the wireless or wired connection? You can use the Powerline to extend wired connection as well as wireless connection.
- ErikRossJul 04, 2016AspirantI'm sorry I was away on business.
the problem is this:I have an ethernet network in my houseroom 1) at the end of my Ethernet network, I don't have wifi coverage, and I would put one wifi extender (Netgear EX6150-100PES AC1200 Mbps WiFi) connected directly to the Ethernet line to get coverage in the area;room 2) while in the other room I only have wifi and I would like extended theEthernet line to connect the playstation and other to my son.I put the image for a better description and more informationThis is the connection that I want to accomplishThanks for your help.
