PollyB
Jul 15, 2016Aspirant
PLW1000 set up - password?
I'm trying to log into my new PowerLINE WiFi PLW1000 and it is asking for a password. I must be blind, because I can't find one in the documentation or on the box where the serial number is.
Anyone?
Anyone?
- Never mind. I finally got a magnifying glass out and looked on the equipment again and found it. I've never seen sucha tiny font!
There are several current discussions with the same question:
Re: PLW 1000 the computer is asking for a password... - NETGEAR Communities
Re: PLW1000 where is the passwords? - NETGEAR Communities
Maybe one of them could help.
- clithesProdigy
If you are browsing to the wifi adapter using http://www.mywifiext.net/ it is simply username: admin password: password until you change it in the settings
- PollyBAspirantI found it.
- PollyBAspirantNever mind. I finally got a magnifying glass out and looked on the equipment again and found it. I've never seen sucha tiny font!
For others in search of the solution, that's the answer that clithes offered here:
With a helpful picture.
