jacksinful
Feb 16, 2016Aspirant
Potential Bandwidth for PL1200 (Powerline AV1200)
Specifications (from manual on netgear product page) say the ethernet port is 100base-tx, how could it even theoretically support 1200mbps?
- Feb 16, 2016
The manual is probably wrong. The tech specs on the website indicate that the Ethernet port is Gigabit (link). Note that 1200 Mbps is the link speed. Because a lot of bits are used for overhead, the actual throughput will be much lower, probably around 200 to 400 Mbps under optimal conditions.
TheEther
Feb 16, 2016Guru
jacksinful
Thanks for the response. The manual is likely wrong, i agree. Its insane, however, that they advertise it as 1200Mbps capable if one can only acheive 15 - 30% of that speed under typical or even optimal conditions. My internet doesnt get much faster than 75Mbps, but I was hoping to get some benefit on my local gigabit network. Oh well, it's seems better than it was with existing wifi. Thanks again.
- clithesFeb 17, 2016Prodigy
My PL1200 and PLP1200 move data around at about 15MB per second. Are you able to achieve around these figures (or better, my wiring isnt great!)
- jacksinfulFeb 17, 2016Aspirant
I get about 35Mbps, going to different floors. It seems decent!
- hcsitas1Feb 18, 2016Aspirant
18, adjacent room, but 2 older PLs in the same network elsewhere.
That's 18 MB/s.
- TheEtherFeb 17, 2016Guru
jacksinful wrote:Thanks for the response. The manual is likely wrong, i agree. Its insane, however, that they advertise it as 1200Mbps capable if one can only acheive 15 - 30% of that speed under typical or even optimal conditions. My internet doesnt get much faster than 75Mbps, but I was hoping to get some benefit on my local gigabit network. Oh well, it's seems better than it was with existing wifi. Thanks again.
It's funny how the gap between Powerline link and actual speeds is as wide as it is on Wi-Fi. I guess it goes to show how difficult it is to carry data across power lines.
