DeeDubz
Jul 06, 2017Follower
Power line 1000 connectivity issues
Im using my power line 1000 to send an internet signal to my DVR for my security cameras. After a few hours the PL 1000 lose the internet connection. Im unable to look at my cameras via the internet....
- Jul 07, 2017
You may find this discussion interesting:
Solved: Re: CHANGED MY MIND GOOD ADAPTERS IF YOU DON'T MIN... - NETGEAR Communities
It explains how one victim of similar symptoms fixed it by using another maker's powerline utility to disable sleep mode on their Netgear plugs.
This also explains what is going on:
Netgear Powerline 1000 - NETGEAR Communities
Paulwms
Jul 08, 2017Aspirant
Michael, THANK YOU!!! I apologize that I didn't find the post you pointed me to when I first searched the Community for a solution. After you pointed me in the right direction, I installed the ZYXEL's PLA5405 Utility. I ran the utility and was able to turn off standby mode in both adapters. I was able to use the MAC addresses to confirm that I was looking at the correct devices and had turned off standby mode in both of them. It has been only a few minutes since I ran the utility so it is to early to tell if standby mode was the problem; although that is the consensus at various websites. Now all I have to do is remember the utility's name if a power outage or unpluging them turns standby mode back on. :) Thanks again.
clithes
Jul 10, 2017Prodigy
In my experience standby mode remains switched off, even after a power cut or you turn the adapter off
