Naton1011
Sep 01, 2018Follower
Power line Light not appearing
Hi, I've been using the AC1900 Nighthawk router upstairs and i have the white adapter which I believe is the 6501 extender down stairs. The wifi extender is getting the WPS light and the wifi light bu...
michaelkenward
Sep 02, 2018Guru - Experienced User
AC1900 is not a Netgear model number. It is a label that Netgear, and others, attach to their hardware to describe their wifi speeds.
You "believe" it is an XAV6501. If so, it will say so on the plug.
If it is an XAV6501 then there will be another Powerline plug connected to the router.
The XAV6501 is not an extender. Nor does it do wifi. So my guess is that you have something else.
Netgear has a range of routers with Powerline built in. The R7300DST router includes the DST6501 as its adapter. Is that the thing you own?
There is a manual for the R7300DST somewhere at the end of this link:
>>>>> R7300DST | Product | Support | NETGEAR <<<<<
