Paul2412's avatar
Paul2412
Follower
Oct 27, 2017
Powerline 1000 but very slow speeds
Hi,
Just installed the PL1000 and the connection works but I'm only getting about 2 mbps download.
I'm using it wired.
If I wired the pc with a direct connection to the router I get about 10 mbps. I know powerlines aren't
as trustworthy when it comes to download speeds as regular lan connections but only 2 mbps is a tad too low.
Are there any settings I can change or.....?
I'm about 5 meters away from the router / other powerline adapter.
Thanks in advance!
  • Hi Paul2412,
    The connection depends on the electrical design of your house. The 2nd adapter maybe close to the 1st adapter but the travel of the data is a bit longer compared to the distance of the two.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Paul2412,
    • JamesGL's avatar
      JamesGL
      Hi Paul2412,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
