Markneedshelp
May 10, 2021Aspirant
Powerline 1000, can I connect anything to make wifi better
Hi,
I have purchased a Netgear powerline 1000 to get a wired connection to the upstairs of the house, as the wifi doesn't reach too good. Whilst that works great for one computer, I wondered if there is a devise I can connect to the Powerline upstairs to effective extend the wifi, so more than one user can benefit.
Thanks for any help
Mark
- plemansGuru - Experienced UserOr you can simply add a router (in access point mode) or an extender in access point mode to the powerline device.
Many routers/extenders have multiple ethernet ports and support wifi. So you'd be able to hardwire in or use it wireless.- MarkneedshelpAspirant
Hi,
Thanks for the reply which is really helpful, much appreciated.
Kind Regards
