MatthewDeMella
Aug 20, 2017Follower
Powerline 1200 ethernet to router?
Hi Does anyone know if I can connect a powerline 1200 adapter to a new router to extend my wifi single?
I bought the Powerline 1200 to extend wifi- but realized it is only ethernet out- not wifi out. And my Macbooks don't have ethernet inputs. So rather than going out to buy the 'correct' netgear product, probably the Netgear powerline 1000 wifi extender, I thought I might try to connect the Powerline 1200 adapter to a cheap router and get my wifi signal that way.
Any thoughts?
Thanks,
Matt
MatthewDeMella wrote:
So rather than going out to buy the 'correct' netgear product, probably the Netgear powerline 1000 wifi extender, I thought I might try to connect the Powerline 1200 adapter to a cheap router and get my wifi signal that way.First, if it isn't too late, why not swap your plugs for the bundle that does include a wifi access point?
Second, you can do what you suggest so long as the router you buy can work as a wifi access point. Most can, but you will have to configure the second router so that it doesn't fight with the main router to be the resident DHCP handing out IP addresses.
The idea is that you plug the second router into the LAN output from the powerline plug
Depending on what other features you want, you might want to look into something here:
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
You don't need a repeater – a box that listens to a remote wifi devices and passes it on to your local wifi clients – although some of these will work as repeaters or access points. with a wired link to the router.
Most routers can work as access points, but only some can be repeaters.
If you have an old router lying around, you could experiment with that. But remember that older equipment may not have the wifi performance that can make the most of your wifi clients.
On the positive side, if you get a decent range extender it may well deliver better performance than the powerline device you thought you had bought.
1 Reply
