Butch65's avatar
Butch65
Powerline 1200 node doesn't power up
Hoping to find that here's a simple solutio! - I purchased the PL1200 months ago, just got around to connecting it due to outlet config / access. One of the nodes ( connected to the TV) powers up fine.  The primary node that connects to the router doesn't indicate any power in - no lights at all.  I tried the factory reset, no change.  Could I have a bum node out of the box? Hope not, as this project has already gone on longer than anticipated.
Thanks for the assisatnce.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Butch65,
    Welcome to Community!
    You can try to swap positions of the two nodes. If still the same behavior then it might be a hardware problem.
    JamesGL
    Community Team
    • Butch65's avatar
      Butch65
      Thanks, James.
      I tried that, as well as several different outlets around the house just for fun!  No power to the extender. I called the help line and they tried to convince me that they needed to update my firmware and config of my system for the unit to power up - and if that did fix it I would be on th hook for a 2 year sevice agreement  costing $149.99.
      I'm returning the unit and will try another....
      • JamesGL's avatar
        JamesGL
        Butch65,
        If it did not work, you can replace it from the store where you purchased it since it might be defective.
        JamesGL
        Community Team
