jtg-thats-me
Nov 14, 2015Follower
Powerline 1200 SLOW
I've got Powerline 1200, and it's really slow. I didn't expect 1200 Mbps, but the max I've been able to get less than a tenth of that, and as little as 72Mbps. Is my electrical system really noisy, o...
clithes
Nov 15, 2015Prodigy
I think you've mis-understood the transfer rates of these adapters. The 14MBps you achieved with the adapters is fairly typical of these units, whilst I agree the 9MBps is a little low.
The best I have achieved with my units is around 17-18MBps
The 'theoretical' transfer rates are very misleading and often a lot higher than actual transfer rates
TheEther
Nov 15, 2015Guru
According to this SmallNetBuilder review, it should be able to hit up to 212 Mbps. Maybe the OP can test with the units in the same or adjacent wall outlets on the same circuit to confirm.
Performance, however, will degrade with distance and noise. The path from downstairs to upstairs could be circuitous and/or involve a lot of connection joints that cause signal reflections.
