Hrusovsky's avatar
Hrusovsky
Follower
Mar 18, 2020
Powerline 2000
I am connecting my Powerline 2000 to get higher speeds for a gaming computer.  I have a modem which is direct wired to the cable/internet company.  This is hooked up to a Netgear Wireless Router.  How do I connect the Powerline 2000 - into the modem or into the wireless router, or both?
  • > Powerline 2000
    > Model: A6150|AC1200 Dual Band WiFi USB Mini Adapter, PLP2000|Powerline
    > 2000 + Extra Outlet
       Is there an A6150 involved here?  Is the actual model number of the
    Powerline device "PLP2000"?
    > [...] I have a modem [...]
       Has it a maker and model number?
    > [...] This is hooked up to a Netgear Wireless Router. [...]
       Has this router a model number?  Where are these devices situated?
    > [...] my Powerline 2000 [...]
    > [...] the Powerline 2000 [...]
       Do you have _one_ Powerline adapter?
       Visit http://netgear.com/support , put in your (actual) model
    number(s), and look for Documentation.  Get the User Manual(s).  Read.
    > [...] to get higher speeds for a gaming computer. [...]
       "higher" than what?
    > [...] How do I connect the Powerline 2000 - into the modem or into the
       You might connect a _pair_ of Powerline adapters to any two devices
    (one adapter to each device) which you wish you could connect using a
    simple Ethernet cable.
       If you're trying to use Powerline adapters to connect your
    (unspecified) "a gaming computer" to your router using a pseudo-wired
    connection (instead of a wireless radio connection), then you'd connect
    one Powerline adapter to a LAN Ethernet port on the router, and another
    Powerline adapter to an Ethernet port on the (unspecified) "a gaming
    computer".  Read the User Manual for the Powerline adapter.  Really.
       Also of possible interest:
          https://community.netgear.com/t5/x/bd-p/home-powerline
  • michaelkenward's avatar
    michaelkenward
    As the manual says, plug cable from PLP2000 into router. That's the usual strategy, but not knowing what the modem and router are, who knows?
    Have you tried it?
    • antinode's avatar
      antinode
      Guru
      > As the manual says, [...]
         Did you actually look at "the manual"?  (Which "the manual"?)
      > [...] plug cable from PLP2000 into router. [...]
         That might be good for one Powerline adapter.  What good is that if
      it's the _only_ Powerline adapter?  If you have a second one, then what
      would you advise doing with it?  (Hint: Actually read the adapter User
      Manual.)
      > [...] That's the usual strategy, [...]
         Perhaps for some of us.
      > [...] but not knowing what the modem and router are, who knows?
         If the modem is a modem, and the router is a router (without any
      built-in Powerline capability), then it hardly matters.  And, if the
      router did have built-in Powerline capability, then that "the usual
      strategy" would be an error.
