Kalidmnd
Oct 29, 2016Aspirant
Powerline 500 XAVB5201 not connecting with Xbox one
I bought this powerline 500 plus wifi access point and set it up and works fine with my phone tv and laptop but when I try to connect my Xbox one it doesn't work and I don't know why and my Xbox can ...
- Apr 13, 2017
Let's unravel this. You say:
Inkyfingerz wrote:
...all of my other devices can connect and are connected at the time I try to connect wirelessly to the extender.Does this mean that you have several wifi devices and that they all connect to the wifi except the XBox?
If so, then this bit is probably wrong:
Inkyfingerz wrote:The problem is not with my Xobox
The wifi plug isn't intelligent enough to block one device while it allows all the others to connect.
It is more likely that there is some wifi setting in the XBox that you need to change.
For example, you have have to ensure that the XBox is using a wifi security protocol that works with the XAVB5201.
As the XAVB5201 isn't a wifi plug, perhaps you could tell us which plugs you are using. Is it the XWNB5201? If so, have you tried connecting using WPS?
Kalidmnd
Oct 30, 2016Aspirant
It says can't connect to the internet and to contact my internet provider
