KAD_UK
Jan 11, 2018Aspirant
PowerLine AV500 Compatibility with New Adapters
Hello, I currently have a few of the Powerline AV500 adaptors in my house. This product is now End of Life. I want to expand my network and add a wireless adaptor which runs from the Powerlin...
- Jan 12, 2018
KAD_UK wrote:
My question is, would this new kit be compatible with the old plugs? If I add the wireless adaptor to a plug socket, will it see the existing PoweLine network and connect?Yes, they will be compatible.
To get the new plugs to talk to the old ones, read this:
>>> Adding a powerline adapter to an existing powerline network <<<
The manuals also tell you what to do.
Be warned that by mixing 500 and 1200 plugs you are limiting the speed of the network to the speed of the slowest plugs. You probably won't notice much difference. But the LAN on the 1200 runs at 1000 Mbps while the others do 100 Mbps.
livefromboredom
Jan 13, 2018Aspirant
I'm having the same issue with my PLW adapter staying hot on my network. It will work for a couple days, and then drop and not be able to find the network again. I set it up on a static IP address and had some great speeds going through it, but came to find it cold again with no internet connectivity after a few hours. With it stating backwards compatibility, I'm still using the XAV as my point of entry instead of the PLW receiver...Should I flip these around?
michaelkenward
Jan 14, 2018Guru - Experienced User
I can't see that this issue has anything to do with the one in the original question. But that's because I don't understand what you have on your powerline network.
What do you mean by "entry point", the plug connected to the router?
And what are the modem numbers involved? Netgear makes a handful of models with the XAV and PLW labels.
You can find the model number on the back of the plugs, conveniently positioned where you cannot see them when the thing is plugged in.
- livefromboredomJan 14, 2018Aspirant
Hey Michael,
Thanks for replying.
I ended up restoring the factory settings on my connectors and establishing the secured network again and all is well.
- michaelkenwardJan 14, 2018Guru - Experienced User
That's good news. Glad it worked out.
