KAD_UK
Jan 11, 2018Aspirant
PowerLine AV500 Compatibility with New Adapters
Hello, I currently have a few of the Powerline AV500 adaptors in my house. This product is now End of Life. I want to expand my network and add a wireless adaptor which runs from the Powerlin...
- Jan 12, 2018
KAD_UK wrote:
My question is, would this new kit be compatible with the old plugs? If I add the wireless adaptor to a plug socket, will it see the existing PoweLine network and connect?Yes, they will be compatible.
To get the new plugs to talk to the old ones, read this:
>>> Adding a powerline adapter to an existing powerline network <<<
The manuals also tell you what to do.
Be warned that by mixing 500 and 1200 plugs you are limiting the speed of the network to the speed of the slowest plugs. You probably won't notice much difference. But the LAN on the 1200 runs at 1000 Mbps while the others do 100 Mbps.
michaelkenward
Jan 12, 2018Guru - Experienced User
KAD_UK
Jan 15, 2018Aspirant
Thanks for the quick reply - sorry for my slow response and acceptance of the answer.
I managed to get the new PowerLine adaptor and as you said it worked perfectly in line with the old ones.
I have updated the plug connected to the router to be the new one (supplied in the pair) and I placed the Wireless Hotspot device where it was required. They work perfectly together (as expected). I also reset the existing 500MB adaptors and they worked on the new network as you said.
Thanks again for your quick and helpful advice.
