KenLark
Dec 28, 2012Aspirant
Powerline Distance
Haven't been able to find a spec for the distance a powerline adapter signal should travel, does anyone know? Apart from the spec, any input on real world distance? Mainly concerned with neighbors being able to access my clients networks by accident or on purpose.
- jmizoguchiVirtuosoPower line has encryption to it will be protected.
Within the same main circuit it should be safely used - KenLarkAspirantI'm aware there is encryption available and that within the same circuit it should be safe. Again, looking for what the spec is for distance. Thanks!
- jmizoguchiVirtuosoask support at my.netgear.com as non register and ASK EXACT distance and environmental factor
