JimPivonka
Feb 07, 2016Follower
Powerline LED lights Red AV200 nano and adapter XAV2101
Using this rig with a Comcast modem had worked fine. Recently users in the attached 'cottage' served by the adapter have experienced communications problems. Checking the modules disclosed that when ...
JamesGL
Feb 24, 2016NETGEAR Employee Retired
Hi JimPivonka,
It is recommended that the powerline adapters are connected in one circuit breaker to get the optimum performance. You may consider the distance of the date travels which will affect the performance. If it works previously, you may need to check your wiring or if no problem with wiring that I would suggest to use an extender instead of powerline.
