1di9
May 25, 2018Tutor
Powerline PLP1200 disconnections
I'm using a couple of PLP1200 Powerline for over a year now and it's been some time I've noticed that, during a day, they disconnet from network several time, letting my Pc without internet or LAN connection; led are green as if it is all working normally. I had to wait some time (ranging from a few to many seconds) before they automatically reconnect.
In these case, In event viewer of my Fritz!box router I can see message "The new powerline adapter ..... has been connected" repeated two times with two different mac address.
I don't think is a matter or some kind of power saving, because often I'm using PC over internet when disconnection occur.
Are they dead?
- nonsapreiAspirant
I have the same problem. I really hope there's actually a way to solve it and that it's not related to the house's wiring, because I'm probably not gonna move anytime soon, and even if I did, the probability of going somewhere with modern wiring isn't high...
P.S. My product is brand new, though. It's been having this problem since the very first day.
P.P.S. I've searched a bit and I found a couple of people saying it can be caused by overheating. My powerline isn't very hot though, but it does have a power strip plugged into the extra outlet. I'll try to plug that into another outlet and also monitor the heat.
- 1di9Tutor
According to me is not an issue house wiring related.....Taking a look around forum, I read about many people complaining about this identical defect.
Overheating? May be.....Then it could be a design error, it must be taken into account that the temperature of this device is subject to increases due to the electric load if it is equipped with a passing outlet.
I'm considering replacing it with something more reliable, like the powerline of the AVM....I use Fritz!box 7490 as router and access point.
- nonsapreiAspirant
I've plugged the power strip into another outlet but the problem still arises even when the device isn't hot... It happened twice in not even 2 hours. I have to just stop using it and go back to wifi...
