cook98765
Jul 30, 2017Aspirant
Powerline PLW1000 slow speed unless rebooted?
Hi guys, I've had my PLW1000 kit for over a year and has seen a total of 3 houses. The first two houses it worked great with no issues whatsoever. I've just recently moved into a new-build house ...
michaelkenward
Jul 31, 2017Guru - Experienced User
cook98765 wrote:
It feels like the kit is going into some sort of sleep mode and not really waking up. As I say, I've had the kit for over a year with no issues like this, only when I've moved into the new house has it started to happen. I've tried to update the firmware using mywifiext.net but it says I'm up to date (V1.0.0.6).
That's a strong possibility.
You will find various messages about that around here. They may put you on the right track:
Netgear Powerline 1000 - NETGEAR Communities
Solved: Re: Power line 1000 connectivity issues - NETGEAR Communities
- cook98765Jul 31, 2017Aspirant
Many thanks for the response.
The top link you have provided, I followed that yesterday and downloaded Zyxel's utility and turned sleep mode off on both adapters. I don't want to tempt fate but I woke up this morning and the speed is as how it should be. I'll keep you posted but it looks like it's sorted :)
Dan
- michaelkenwardJul 31, 2017Guru - Experienced User
Well done.
cook98765 wrote:
I'll keep you posted but it looks like it's sorted :)That would be great.
Pity it takes Zyxel to mend Netgear's hardware.
