laworder
Mar 15, 2023Aspirant
Powerline PLW1000v2 "no valid IP address"
Have installed one of these, initiall I got it working and it ran well, very fast, but it stopped working this morning. I have all the correct lights according to the manual, I have Wifi but no inter...
laworder
Mar 17, 2023Aspirant
michaelkenward wrote:
laworder wrote:I am starting to wonder if this is something to do with the power saving feature kicking in and the router dropping the DHCP to the LAN port as a result and not starting it up again when we go to use it again
Good thinking. That has been an issue with Powerline plugs.
Unfortunately, Netgear no longer provides management software for its plugs. But the programs from other brands seem to do the job.
Also cant log into the mywifiext page for this, never have been able to, get connection refused.
How are you going about it? If you can find its IP address, throw a browser at that. Might let you in.
Not sure that you will find the power settings in there. I no longer use my WiFi plus. Instead, I use the plugs to connect AP devices to the network.
Found the IP address off my router and tried it in old Internet Explorer - success! The Netgear Genie portal loaded up fine. Unfortunately nothing in there that allows me to turn off the power saving feature. I have Firmware Version V1.0.0.18 dont know if thats going to make any difference
Any suggestions as to some management software that will let me turn that **bleep** off? Cant believe Netgear are still selling product that they no longer provide management software for, these things are still widely available here, I bought mine a week ago and there was plenty more in stock
michaelkenward
Mar 17, 2023Guru - Experienced User
ZyXel is one name that has cropped up here. I used it a while back.
And it isn't just the WifI plug that needs attention. They all suffer from sleep disorders.
You can either search for something suitable on Google, or see what turns up with a local search.
Powerline PLW1000 slow speed unless rebooted? - NETGEAR Communities
Netgear Powerline 1000 - NETGEAR Communities
Solved: Netgear Powerline Utility for Windows - NETGEAR Communities
PL1200 and PLP1200 Powerline Utility / Netgear Gen... - NETGEAR Communities
