Growl's avatar
Growl
PowerLINE Wifi 1000 password reset issues
I can't log back into my router after doing a factory reset. It will not recognise the password.
I'm currently on Mac and can't try the windows software. I can't get help because my support expired 3 months after purchasing the product.
Any help appreciated.
  • Fixed.
    I installed a network scanner on my iPad (Fing) to get the IP address of the WiFi access point. Then logged into that using the default username/password.
    This was after leaving the device unplugged for a couple of days.
    Hope this helps someone who is having same issues as I was.
    If I didn't fix this myself I would be stuck with a paper weight. And the fact that there is no warranty coverage after 3 months is appalling. In future I will not be purchasing any more Netgear products.
    • michaelkenward's avatar
      michaelkenward
      It would be appalling if it were true. It isn't.
      The three months (90 days) applies to the free support. Warranties are at least a year, depending on where you are.
      • Growl's avatar
        Growl
        I purchased my device on March 7th this year, and after registering, it came up with the following:
        Product Warranty Information
        Product: PL1010v2
        Country of Purchase: Japan
        Purchased on: 2021-03-01
        Standard Product Warranty:
        Hardware Warranty: Expired
        Phone Support: Expired
        Email Support: Expired
        Chat Support: Expired
        Power Supply Warranty: Expired
        Accessories Warranty: Expired
        I bought it from Amazon.com and shipped it to Japan but that shouldn't limit my warranty ans I can happily post it back to the states. I also attached the Amazon receipt for my registration but that has made no difference.
        Anyways attached a screenshot of the above.
