Mosslucy
Mar 04, 2019Follower
Powerline XAVB1301 Are Both devices interchangeable?
I have a spare XAVB1301 powerline unit and I want to add it as another receiver in another room (the original is connected to the router). I bought 2 packs.
Are both the units in the pack interchan...
Blanca_O
Mar 07, 2019NETGEAR Employee Retired
Hi Mosslucy
You should be able to add your extra XAVB1301 set to your existing setup. And yes, the adapters are interchangeable. It can be a receiver or sender.
Please check this link to know more about XAV1301 : https://kb.netgear.com/20777/XAV1301-FAQ
If it will not sync, bring all adapter same room where the router and pair them one at a time. Once done, you can place the adapter where you wished it to be located.
Blanca
Community Team
