wbeech
Mar 08, 2021Aspirant
PWL1010 Connection but no internet
Just got this product this week: Two questions: 1. No lights appear on the base unit(the one that is wired to the router) but it seems to connect(?). 2. When I move the remote wireless unit to my ...
michaelkenward
Mar 09, 2021Guru - Experienced User
Two questions:
You should see several lit LEDs.
What tells you that it "seems to connect"?
What do the LEDs look like on the "remote" plug?
wbeech wrote:
2. When I move the remote wireless unit to my detached garage it appears to connect but there is no internet connection.
Have you tested the plug and confirmed that they work when the AP plug is near to the "source" plug? Do that to confirm that the plugs are properly set up and then move the plug to the preferred location.
What tells you that "there is no internet connection"? You see some sort of error message on the wifi clients you are trying to connect?
wbeech
Mar 09, 2021Aspirant
Guru, When you say "plug" I assume you are referring to the 110v house outlet. They all work and feed through a common breaker box.
