BAnslow
Jun 22, 2016Aspirant
XAV5602 stop working
Hi, I wonder if someone can help. Just over three years ago, I purchased a pair of Powerline AV500, (XAV5602). I plugged them in, and they worked, right up to a couple of months ago. ...
JamesGL
Oct 13, 2016NETGEAR Employee Retired
Hi Feynek,
Thank you for the clarification. What are the lights lit up with the 2nd powerline? It might be a hardware issue since another powerline adapter works with the 1st adapter.
JamesGL
Community Team
Feynek
Oct 14, 2016Tutor
Hi James!
The 2nd powerline had all light but this one did'nt had light =s
- michaelkenwardOct 15, 2016Guru - Experienced User
Feynek wrote:...this one did'nt had light =s
No lights = broken.
See page 11 of English User Manual:
XAV5602 | Product | Support | NETGEAR
That shows what each light tells you.
The power light is the important one:
- Solid green. The electrical power is on.
- Blinking green. The adapter is setting up security.
- Amber. The adapter is in power saving mode. If the Ethernet port is inactive for more than ten minutes, the adapter enters power saving mode.
- The adapter does not have electrical power or the LEDs were off using NETGEAR genie.
Remember, there may be an on/off switch on the bottom.
Web you say "power trip", I assume that this means that it you plug something into the power socket that works.
- FeynekOct 15, 2016Tutor
Damnit, what can i do/ ='(
Buy a new one.
