PeteNVA
Aug 11, 2016Aspirant
Red Light Flashes - XBox not working
I have been using a several Netgear Powerline PL 1200 adapters on Verizon FIOS, and they worked fine (Plug n Play). Since switching to Cox on Monday, third light flashes red. My XBox gets 30 MB down load and 24 MB up with some packets lost and latency of around 115. On Verizon I was getting 70 Mbps download and 50Mb upload with no packets lost and minimal latency.
Cox says since it's home network they can't help.
My setup:
ISP: Cox Communications with 200 Mbps download and 20 Mbps upload
Cable Modem: ARRIS Touchstone TG2472
4 Powerline PL1200 Adapters
1 Reply
- clithesProdigy
Since you have changed ISP, and are now experiencing lost packets, I would check your MTU settings, as these could be different to your previous internet supplier.
http://www.tp-link.com/en/FAQ-190.html
Once you've found the correct setting, if it is different to before change the MTU value in your modem/router and see what effect that has.
Hope this helps
