RobinWorlidge's avatar
Nov 13, 2016
Using Powerline 1200 and virgin media broadband. Keep getting speed reductions
Get good speed of 100+ mbps, but it does drop to less than 50 a lot of the time. If I switch of the powerline 1200 connected to the router, and switch it back on again, I instantly go back up to 100+ mbps again. Anyone got any ideas as to what the problem is, or a fix please?
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi RobinWorlidge,
    How far is the 2nd adapter from the 1st powerline adapter? You may try relocating it to a closer location from the 1st powerline and test the connection speed.
    JamesGL
    Community Team
    • RobinWorlidge's avatar
      RobinWorlidge
      Hi JamesGL
      It is only about 15 feet away in the next room. Don't have to reboot the powerline that my pc is plugged into, just the one that the router is plugged into in the other room. Don't even have to reboot the router, just the powerline. Have tried swapping over the powerlines, but still get the same problem - have to reboot the powerline that the router is plugged into, so it doesn't seem to be a problem with the powerlines?
      Regards
      Robin
      • JamesGL's avatar
        JamesGL
        Hi RobinWorlidge,
        We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
        JamesGL
        Community Team
