nball12
Aug 30, 2016Follower
Using powerline adapter with router
I want to use my PLW1000 powerline adapter with a second router on my network. The router im trying to use is a linksys wrt120n. I have to cat5 from the powerline adapter hooked into the internet por...
TheEther
Aug 31, 2016Guru
It sounds like you have the wiring worked out. What other help do you need? What are you planning to use the second router for?
michaelkenward
Aug 31, 2016Guru - Experienced User
...and a network map would help.
What is connected to what?
